Разница как между моторами ГАЗ и УАЗ. 70% запчастей взаимозаменяемы.
[color=rgb(0,0,0);font-family:verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif;font-size:13.333333015441895px;]While both Kubota and Yanmar build and sell tractor engines etc, there are some differences of approach re design philosophy for small marine diesels between the two companies.[/color]
[color=rgb(0,0,0);font-family:verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif;font-size:13.333333015441895px;]Most new yanmars in the ~<75 hp range are lighter weight and run at considerably higher [/color]rpm[color=rgb(0,0,0);font-family:verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif;font-size:13.333333015441895px;]than the equivalent Kubota. Some folks like that feature, others view it as a drawback. I personally prefer a bit more [/color]displacement[color=rgb(0,0,0);font-family:verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif;font-size:13.333333015441895px;] and lower engine speeds, and am pretty happy with my Kubota based Nanni 43 hp. This is a simple 2 litre tractor engine which is red-lined at 2800 [/color]rpm[color=rgb(0,0,0);font-family:verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif;font-size:13.333333015441895px;]. I believe that the similar hp Yanmar is a bit less [/color]displacement[color=rgb(0,0,0);font-family:verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif;font-size:13.333333015441895px;], and is red lined at 3600. Yanmar owners correct me if I'm wrong here...[/color]
[color=rgb(0,0,0);font-family:verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif;font-size:13.333333015441895px;]At any rate, most any modern marine diesel, if maintained and run reasonably will last for many, many hours. The routine [/color]maintenance[color=rgb(0,0,0);font-family:verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif;font-size:13.333333015441895px;] does vary between marques, though... eg, Yanmar views their exhaust mixing elbows as a regular replacement item on some engines. These are pricey and IMO should last a hell of a lot longer than what Yanmar figures! The one on my engine has over 4000 hours usage and seems fine.[/color]
Подшипники и сальники у них, конечно, стандартные, думаю, такие же как у ГАЗ и УАЗ.
