Продам двигатель
350CI / 350HP GTO/MAS SMALL BLOCK
This engine doesn't sacrifice power or durability with its four-bolt main block, cast steel crankshaft, Eagle connecting rods, and aluminum pistons. Add to the strong foundation a pair of Dart iron 64cc cylinder heads with 1.94'' intake and 1.50'' exhaust valves, yielding a healthy 10:1 compression ratio.
350 HP @ 5200 RPM
390 ft/lbs torque @ 3400 RPM (Max Recommended RPM: 5500)
Compression Ratio: 10:1
New Cast Iron 4-Bolt Block with One-Piece Rear Main Seal
Cast Steel Crankshaft
Speed Pro Pistons
Eagle 5.7 I-Beam Connecting Rods with ARP Rod bolts
Dart Cast Iron 64cc Cylinder Heads (1.94" Int/1.50" Exh valves)
Aluminum valve covers
Dual Pattern Cam
1.5 Ratio Rocker Arms
MSD/HEI Distributor
Holley 600 Carburetor
и редуктор к нему
2.09:1 Super Wide Stinger Gear Box (750 HP) Soft Drive
Второй мотор
The most versatile engine at a great competitive price. It all starts with a 383 cubic inch block and the Edelbrock E-Tec cylinder heads, offering an incredible 480 ft/lbs of torque @ 4400 RPM with a smooth linear delivery. The combination of a 4.000" bore and 3.750" stroke steel crank and hydraulic camshaft produces 462 HP @ 5500 RPM.
Specifications
Horsepower: 450 @ 5200 RPM
Torque: 480 ft/lbs @ 4400 RPM
Block: Cast Iron 4-Bolt Main with 1-piece rear main seal
Crankshaft: Forged 4340 Steel (externally balanced)
Connecting Rods: 5.7 I Beam with ARP Bolts
Pistons: Forged Aluminum
Camshaft: Hydraulic
Rockers: 1.5:1
Cylinder Heads: Aluminum Edelbrock E-Tec 62cc chamber
Intake: Edelbrock RPM Airgap
Carburetor: QuickFuel 750cfm Mechanical Secondary
Ignition: HEI
Additional Parts Included:
8" balancer
5-quart oil pan with windage tray
Aluminum valve covers with oil cap (provisions for PCV breather)
Painted Steel front timing cover
Engine oil dipstick and tube (passenger side)
Brass freeze plugs
Spark Plugs
Редуктор такой же, 2:09
Всё находится в Красноярске.
Комплект 350л.с. 1300000р
Комплекто 450 л.с. 1500000р
Нет коллекторов, т.к. неизвестно расположение компонетов лодки и американцы их не вставляют в комплект
