/********************************************************************* Various Maple tests.. including timer capture to memory via dma =) включая захват таймера в память через dma */ #include "usb.h" #include "timer.h" #include "dma.h" int PRESCALE=1 ; //32 ; //128; int WAIT=1 ; //50; int g=0 ; int k=0 ; int j=0 ; int TRIGGER=26 ; int BEAM=25 ; int PULSE=27 ; float RANGE=9 ; // range us //quick method to return if there's anyone on the other end of the serialusb link yet. boolean isConnected(){ return (SerialUSB.isConnected() && (SerialUSB.getDTR() || SerialUSB.getRTS())); } void setup(){ SerialUSB.begin(); while(!isConnected()); //wait till console attaches. SerialUSB.println("Hello!"); SerialUSB.print(" Prescale: "); SerialUSB.println(PRESCALE); pinMode(27,INPUT_PULLDOWN); //pinMode(26, INPUT_PULLUP); pinMode(TRIGGER, INPUT_PULLDOWN); pinMode(BEAM, INPUT); } /********************************************************************** timer tests.. seeing if the timer clock really does run at 72mhz.. */ volatile int overflowCount=0; void countOverflows(){ overflowCount++; } //int PRESCALE=8 ; //32 ; //128; //int WAIT=50; int results[16]; int overflow[16]; void testHardwareTimer(HardwareTimer t){ t.attachInterrupt(1,countOverflows); for(int i=0; i<16; i++){ t.setCount(0); overflowCount=0; t.resume(); delayMicroseconds(WAIT); // delay(WAIT); t.pause(); results[i]=t.getCount(); overflow[i]=overflowCount; } t.detachInterrupt(1); } void printResults(){ SerialUSB.print("Timing results: "); for(int i=0; i<16; i++){ SerialUSB.print(results[i]); SerialUSB.print(" "); } SerialUSB.println(); SerialUSB.print("Overflows: "); for(int i=0; i<16; i++){ SerialUSB.print(overflow[i]); SerialUSB.print(" "); } SerialUSB.println(); SerialUSB.print("Each count worth approx (ns): "); for(int i=0; i<16; i++){ SerialUSB.print( waitToNanos(overflow[i], results[i]) ); SerialUSB.print(" "); } SerialUSB.println(); } double expectedTimePeriod(){ //in nanos.. so 72mhz = 72000khz = 72000000hz 1/72000000hz = tick in seconds // 1/72000 = tick in ms, 1/72 = tick in us (1/72) * 1000 = tick in ns //tick in ns * prescale == time которое мы должны видеть //we're supposed to see return ((double)1.0 / ((double)72.0)) * (double)1000.0 * (double)PRESCALE; } double waitToNanos( int overflows, int count ){ //wait is in millis, *1000 for micros, *1000 for nanos double time = (((double)WAIT * (double)1000.0)) ; // * (double)1000.0) ) ; time = time / ((double)count + ((double)65535*(double)overflows)); return time; } int readInt(char terminator){ char current; int output=0; while(SerialUSB.available() && (current=SerialUSB.read())!=terminator){ if(current>='0' && current<='9'){ output=output*10; output+=(current-'0'); }else{ output=-1; break; } } return output; } HardwareTimer timer2 = HardwareTimer(2); HardwareTimer timer1 = HardwareTimer(1); void timingTest(){ SerialUSB.println("Starting Timing test"); SerialUSB.print(" Prescale: "); SerialUSB.println(PRESCALE); SerialUSB.print(" Wait Period (us): "); SerialUSB.println(WAIT); SerialUSB.print(" Expected value for each tick :"); SerialUSB.println(expectedTimePeriod()); timer1.pause(); timer2.pause(); timer2.setMode(TIMER_CH1, TIMER_OUTPUT_COMPARE); timer2.setPrescaleFactor(PRESCALE); timer2.setOverflow(65535); timer2.setCompare(1,65535); timer2.setCount(0); timer2.refresh(); timer1.setMode(TIMER_CH1, TIMER_OUTPUT_COMPARE); timer1.setPrescaleFactor(PRESCALE); timer1.setOverflow(65535); timer1.setCompare(1,65535); timer1.setCount(0); timer1.refresh(); testHardwareTimer(timer1); printResults(); testHardwareTimer(timer2); printResults(); } /****************************************************************************** DMA from Timer Capture to array test.. */ //number of captures to do.. #define TIMERS 100 //512 volatile int exit=0; //set to 1 when dma complete. volatile uint16 data[TIMERS]; //place to put the data via dma //dump routine to show content of captured data. void printData(){ SerialUSB.print("DATA: "); for(int i=0; i<TIMERS; i++){ SerialUSB.print(data[i]); SerialUSB.print(" "); } SerialUSB.println(); } //активизировать (invoked) as configured by the DMA mode flags. void dma_isr() { dma_irq_cause cause = dma_get_irq_cause(DMA1, DMA_CH2); //using serialusb to print messages here is nice, but //it takes so long, we may never exit this isr invocation //before the next one comes in.. (dma is fast.. m'kay) switch(cause) { case DMA_TRANSFER_COMPLETE: // Transfer completed SerialUSB.println("DMA Complete"); exit=1; break; case DMA_TRANSFER_HALF_COMPLETE: // Transfer is half complete SerialUSB.println("DMA Half Complete"); break; case DMA_TRANSFER_ERROR: // An error occurred during transfer SerialUSB.println("DMA Error"); exit=1; break; default: // Something went horribly wrong. // Should never happen. SerialUSB.println("DMA WTF"); exit=1; break; } } void loop(){ //simple main loop, listens for a char, and uses it as a command //to select what task to perform // // a echo test // b echo test // c serialusb disable/enable test // d time the timer test, default params // e time the timer test, user supplied args // f DMA timer capture of pulse widths from D6 straight to memory while(!SerialUSB.available()); char cmd = SerialUSB.read(); switch(cmd) { case 'a': { SerialUSB.println("Hello"); break; } case 'b': { SerialUSB.println("There"); break; } case 'c': { SerialUSB.println("Going away for a while"); SerialUSB.end(); usbPowerOff(); delay(5000); usbPowerOn(); SerialUSB.begin(); delay(5000); while(!isConnected()); SerialUSB.println("Welcome back"); break; } case 'd': { // WAIT=50; // PRESCALE=128; timingTest(); printData(); break; } case 'p': { printData(); break; } case 'i': { // attachInterrupt(26, blink, RISING); attachInterrupt(TRIGGER, TRIGGER_ON, FALLING); // printData(); break; } case 'e': { int arg1=0; int arg2=0; if(!SerialUSB.available()) goto usage; if(SerialUSB.read()!=' ') goto usage; arg1 = readInt(' '); arg2 = readInt(' '); if(arg1==-1 || arg2==-1) goto usage; SerialUSB.print("Setting prescale to: "); SerialUSB.println(arg1); SerialUSB.print("Setting wait to: "); SerialUSB.println(arg2); WAIT=arg2; PRESCALE=arg1; timingTest(); goto done; usage: SerialUSB.println("Usage: e <prescale> <wait>"); SerialUSB.println(" eg. e 128 200 for a prescale of 128 and wait of 200"); done: break; } case 'f':{ timer_dev *t = TIMER1; timer1.pause(); timer1.setPrescaleFactor(PRESCALE) ; //128); timer1.setOverflow(65535); timer1.setCount(0); timer1.refresh(); timer_reg_map r = t->regs; //using timer1, channel1, maps to pin d27 //according to maple master pin map. // pinMode(27,INPUT_PULLUP); //capture compare regs TIMx_CCRx used to hold val after a transition on corresponding ICx //when cap occurs, flag CCXIF (TIMx_SR register) is set, //and interrupt, or dma req can be sent if they are enabled. //if cap occurs while flag is already high CCxOF (overcapture) flag is set.. //CCIX can be cleared by writing 0, or by reading the capped data from TIMx_CCRx //CCxOF is cleared by writing 0 to it. //Capture/Compare 1 Selection // set CC1S bits to 01 in the capture compare mode register. // 01 selects TI1 as the input to use. (page 336 stm32 reference) // (assuming here that TI1 is D6, according to maple master pin map) //CC1S bits are bits 0,1 bitSet(r.adv->CCMR1, 0); bitClear(r.adv->CCMR1, 1); //Input Capture 1 Filter. // need to set IC1F bits according to a table saying how long // we should wait for a signal to be 'stable' to validate a transition // on the input. // (page 336 stm32 reference) //IC1F bits are bits 7,6,5,4 bitClear(r.adv->CCMR1, 7); bitClear(r.adv->CCMR1, 6); bitSet(r.adv->CCMR1, 5); bitSet(r.adv->CCMR1, 4); //sort out the input capture prescaler.. //00 no prescaler.. capture is done as soon as edge is detected bitClear(r.adv->CCMR1, 3); bitClear(r.adv->CCMR1, 2); //select the edge for the transition on TI1 channel using CC1P in CCER //CC1P is bit 1 of CCER (page 339) // 0 = falling // 1 = rising bitClear(r.adv->CCER,1); //set the CC1E bit to enable capture from the counter. //CCE1 is bit 0 of CCER (page 339) bitSet(r.adv->CCER,0); //enable dma for this timer.. //sets the Capture/Compare 1 DMA request enable bit on the DMA/interrupt enable register. //bit 9 is CC1DE as defined on page 329. bitSet(r.adv->DIER,9); dma_init(DMA1); dma_setup_transfer( DMA1, //dma device, dma1 here because that's the only one we have DMA_CH2, //dma channel, channel2, because it looks after tim1_ch1 (timer1, channel1) &(r.adv->CCR1), //peripheral address DMA_SIZE_16BITS, //peripheral size data, //memory address DMA_SIZE_16BITS, //memory transfer size (0 //| DMA_FROM_MEM //set if going from memory, don't set if going to memory. | DMA_MINC_MODE //auto inc where the data does in memory (uses size_16bits to know how much) | DMA_TRNS_ERR //tell me if it's fubar //| DMA_HALF_TRNS //tell me half way (actually, don't as I spend so long there, I dont see 'complete') | DMA_TRNS_CMPLT //tell me at the end ) ); fff() ; printData(); break; } case 's':{ pinMode(27,INPUT_PULLUP); for(g=0 ;g<4 ;g++){ timer_dev *t = TIMER1; timer1.pause(); timer1.setPrescaleFactor(PRESCALE) ; //128); timer1.setOverflow(65535); timer1.setCount(0); timer1.refresh(); timer_reg_map r = t->regs; //using timer1, channel1, maps to pin d27 //according to maple master pin map. //capture compare regs TIMx_CCRx used to hold val after a transition on corresponding ICx //when cap occurs, flag CCXIF (TIMx_SR register) is set, //and interrupt, or dma req can be sent if they are enabled. //if cap occurs while flag is already high CCxOF (overcapture) flag is set.. //CCIX can be cleared by writing 0, or by reading the capped data from TIMx_CCRx //CCxOF is cleared by writing 0 to it. //Capture/Compare 1 Selection // set CC1S bits to 01 in the capture compare mode register. // 01 selects TI1 as the input to use. (page 336 stm32 reference) // (assuming here that TI1 is D6, according to maple master pin map) //CC1S bits are bits 0,1 bitSet(r.adv->CCMR1, 0); bitClear(r.adv->CCMR1, 1); //Input Capture 1 Filter. // need to set IC1F bits according to a table saying how long // we should wait for a signal to be 'stable' to validate a transition // on the input. // (page 336 stm32 reference) //IC1F bits are bits 7,6,5,4 bitClear(r.adv->CCMR1, 7); bitClear(r.adv->CCMR1, 6); bitSet(r.adv->CCMR1, 5); bitSet(r.adv->CCMR1, 4); //sort out the input capture prescaler.. //00 no prescaler.. capture is done as soon as edge is detected bitClear(r.adv->CCMR1, 3); bitClear(r.adv->CCMR1, 2); //select the edge for the transition on TI1 channel using CC1P in CCER //CC1P is bit 1 of CCER (page 339) // 0 = falling // 1 = rising bitClear(r.adv->CCER,1); //set the CC1E bit to enable capture from the counter. //CCE1 is bit 0 of CCER (page 339) bitSet(r.adv->CCER,0); //enable dma for this timer.. //sets the Capture/Compare 1 DMA request enable bit on the DMA/interrupt enable register. //bit 9 is CC1DE as defined on page 329. bitSet(r.adv->DIER,9); dma_init(DMA1); dma_setup_transfer( DMA1, //dma device, dma1 here because that's the only one we have DMA_CH2, //dma channel, channel2, because it looks after tim1_ch1 (timer1, channel1) &(r.adv->CCR1), //peripheral address DMA_SIZE_16BITS, //peripheral size data, //memory address DMA_SIZE_16BITS, //memory transfer size (0 //| DMA_FROM_MEM //set if going from memory, don't set if going to memory. | DMA_MINC_MODE //auto inc where the data does in memory (uses size_16bits to know how much) | DMA_TRNS_ERR //tell me if it's fubar //| DMA_HALF_TRNS //tell me half way (actually, don't as I spend so long there, I dont see 'complete') | DMA_TRNS_CMPLT //tell me at the end ) ); fff() ; } //for printData(); break; } } } void fff() { dma_attach_interrupt(DMA1, DMA_CH2, dma_isr); //hook up an isr for the dma chan to tell us if things happen. dma_set_num_transfers(DMA1, DMA_CH2, TIMERS); //only allow it to transfer TIMERS number of times. dma_enable(DMA1, DMA_CH2); //enable it.. timer1.resume(); // while(!exit); delayMicroseconds(RANGE) ; // exit=1; // detachInterrupt(PULSE) ; // timer1.pause(); dma_disable(DMA1, DMA_CH2); dma_detach_interrupt(DMA1, DMA_CH2); // printData(); detachInterrupt(BEAM) ; printData(); j=j+1 ; SerialUSB.print("j=");SerialUSB.println(j); //////////////////////////////////// DMA_RET () ; attachInterrupt(BEAM, BEAM_ON , RISING); } //void blink(){ // attachInterrupt(PULSE, ....., FALLING); //detachInterrupt(BEAM) ; // delay(2) ; // fff() ; //} void TRIGGER_ON(){ DMA_FT () ; attachInterrupt(BEAM, fff , RISING); // detachInterrupt(TRIGGER) ; // attachInterrupt(TRIGGER, NEXT_ROT, FALLING); k=k+1 ; j=0 ; // delay(2) ; } void BEAM_ON(){ // j=j+1 ; fff () ; // dma_disable(DMA1, DMA_CH2); // dma_detach_interrupt(DMA1, DMA_CH2); // attachInterrupt(PULSE, fff , RISING); // attachInterrupt(PULSE, ....., FALLING); // detachInterrupt(PULSE) ; // delay(2) ; // blink() ; } /* void NEXT_ROT(){ j=j+1 ; attachInterrupt(PULSE, blink, RISING); // attachInterrupt(PULSE, ....., FALLING); // detachInterrupt(PULSE) ; // delay(2) ; blink() ; } */ void DMA_RET() { // pinMode(27,INPUT_PULLUP); timer_dev *t = TIMER1; timer1.pause(); // timer1.setPrescaleFactor(PRESCALE) ; //128); // timer1.setOverflow(65535); timer1.setCount(0); timer1.refresh(); timer_reg_map r = t->regs; /* //using timer1, channel1, maps to pin d27 //according to maple master pin map. // pinMode(27,INPUT_PULLUP); //capture compare regs TIMx_CCRx used to hold val after a transition on corresponding ICx //when cap occurs, flag CCXIF (TIMx_SR register) is set, //and interrupt, or dma req can be sent if they are enabled. //if cap occurs while flag is already high CCxOF (overcapture) flag is set.. //CCIX can be cleared by writing 0, or by reading the capped data from TIMx_CCRx //CCxOF is cleared by writing 0 to it. //Capture/Compare 1 Selection // set CC1S bits to 01 in the capture compare mode register. // 01 selects TI1 as the input to use. (page 336 stm32 reference) // (assuming here that TI1 is D6, according to maple master pin map) //CC1S bits are bits 0,1 bitSet(r.adv->CCMR1, 0); bitClear(r.adv->CCMR1, 1); //Input Capture 1 Filter. // need to set IC1F bits according to a table saying how long // we should wait for a signal to be 'stable' to validate a transition // on the input. // (page 336 stm32 reference) //IC1F bits are bits 7,6,5,4 bitClear(r.adv->CCMR1, 7); bitClear(r.adv->CCMR1, 6); bitSet(r.adv->CCMR1, 5); bitSet(r.adv->CCMR1, 4); //sort out the input capture prescaler.. //00 no prescaler.. capture is done as soon as edge is detected bitClear(r.adv->CCMR1, 3); bitClear(r.adv->CCMR1, 2); //select the edge for the transition on TI1 channel using CC1P in CCER //CC1P is bit 1 of CCER (page 339) // 0 = falling // 1 = rising bitClear(r.adv->CCER,1); //set the CC1E bit to enable capture from the counter. //CCE1 is bit 0 of CCER (page 339) bitSet(r.adv->CCER,0); //enable dma for this timer.. //sets the Capture/Compare 1 DMA request enable bit on the DMA/interrupt enable register. //bit 9 is CC1DE as defined on page 329. bitSet(r.adv->DIER,9); */ // dma_init(DMA1); dma_setup_transfer( DMA1, //dma device, dma1 here because that's the only one we have DMA_CH2, //dma channel, channel2, because it looks after tim1_ch1 (timer1, channel1) &(r.adv->CCR1), //peripheral address DMA_SIZE_16BITS, //peripheral size data, //memory address DMA_SIZE_16BITS, //memory transfer size (0 //| DMA_FROM_MEM //set if going from memory, don't set if going to memory. // | DMA_MINC_MODE //auto inc where the data does in memory (uses size_16bits to know how much) // | DMA_TRNS_ERR //tell me if it's fubar //| DMA_HALF_TRNS //tell me half way (actually, don't as I spend so long there, I dont see 'complete') // | DMA_TRNS_CMPLT //tell me at the end ) ); // fff() ; // printData(); } void DMA_FT() { timer_dev *t = TIMER1; timer1.pause(); timer1.setPrescaleFactor(PRESCALE) ; //128); timer1.setOverflow(65535); timer1.setCount(0); timer1.refresh(); timer_reg_map r = t->regs; //using timer1, channel1, maps to pin d27 //according to maple master pin map. // pinMode(27,INPUT_PULLUP); //capture compare regs TIMx_CCRx used to hold val after a transition on corresponding ICx //when cap occurs, flag CCXIF (TIMx_SR register) is set, //and interrupt, or dma req can be sent if they are enabled. //if cap occurs while flag is already high CCxOF (overcapture) flag is set.. //CCIX can be cleared by writing 0, or by reading the capped data from TIMx_CCRx //CCxOF is cleared by writing 0 to it. //Capture/Compare 1 Selection // set CC1S bits to 01 in the capture compare mode register. // 01 selects TI1 as the input to use. (page 336 stm32 reference) // (assuming here that TI1 is D6, according to maple master pin map) //CC1S bits are bits 0,1 bitSet(r.adv->CCMR1, 0); bitClear(r.adv->CCMR1, 1); //Input Capture 1 Filter. // need to set IC1F bits according to a table saying how long // we should wait for a signal to be 'stable' to validate a transition // on the input. // (page 336 stm32 reference) //IC1F bits are bits 7,6,5,4 bitClear(r.adv->CCMR1, 7); bitClear(r.adv->CCMR1, 6); bitSet(r.adv->CCMR1, 5); bitSet(r.adv->CCMR1, 4); //sort out the input capture prescaler.. //00 no prescaler.. capture is done as soon as edge is detected bitClear(r.adv->CCMR1, 3); bitClear(r.adv->CCMR1, 2); //select the edge for the transition on TI1 channel using CC1P in CCER //CC1P is bit 1 of CCER (page 339) // 0 = falling // 1 = rising bitClear(r.adv->CCER,1); //set the CC1E bit to enable capture from the counter. //CCE1 is bit 0 of CCER (page 339) bitSet(r.adv->CCER,0); //enable dma for this timer.. //sets the Capture/Compare 1 DMA request enable bit on the DMA/interrupt enable register. //bit 9 is CC1DE as defined on page 329. bitSet(r.adv->DIER,9); dma_init(DMA1); dma_setup_transfer( DMA1, //dma device, dma1 here because that's the only one we have DMA_CH2, //dma channel, channel2, because it looks after tim1_ch1 (timer1, channel1) &(r.adv->CCR1), //peripheral address DMA_SIZE_16BITS, //peripheral size data, //memory address DMA_SIZE_16BITS, //memory transfer size (0 //| DMA_FROM_MEM //set if going from memory, don't set if going to memory. //| DMA_MINC_MODE //auto inc where the data does in memory (uses size_16bits to know how much) //| DMA_TRNS_ERR //tell me if it's fubar //| DMA_HALF_TRNS //tell me half way (actually, don't as I spend so long there, I dont see 'complete') //| DMA_TRNS_CMPLT //tell me at the end ) ); }
пример, мини мэпл, с мэпл компилятором.
Сообщение отредактировал nvc: 15 марта 2020 - 14:27
Добавил теги code
