Добрый вечер!
Достался мне Garmin GPS 45 и вроде все работает все переключается страницы листаются.Только НЕ видет спутники и пишет search the sky.
Помогите пожалуйста разобратся.Может там что с настройками не так ,.
Буду рад любому совету!
Помогите с Garmin GPS 45
Автор
Aleksandr13-76
, 08 апр 2008 19:56
Сообщений в теме: 4
Отправлено 09 апреля 2008 - 23:55
Да я спасибо ,понял что не в квартире.Проверять надо!
Вот вчера нашел инфу может кому будет интересно
The final method used by your Garmin enables it to find itself and get a lock completely without any outside help. In autolocate mode the unit does not use the internal almanac data but instead just uses brute force techniques to find the satellites. On any of the older multiplex receivers this can take 7.5 minutes to 15 minutes with a clear view of the sky for it to gather enough data to acquire a 2D fix. On the 12 channel parallel units the time has been reduced considerably since much of the data can be gathered simultaneously using the 12 channels. A 3D fix under these conditions can usually be obtained in about 3 to 5 minutes. Note that while a fix may be obtained, this is not sufficient time to reload the full almanac. The almanac requires 12.5 minutes to download from the satellites. For this reason, if you have to do an autolocate you should continue to leave the unit on while it regathers its full almanac, or you may have a similar problem the next time you turn it on.
If the unit is doing an autolocate and it fails to produce a 3D lock it may prompt you for the altitude reading. You should enter something as close as possible to what you might guess it to be. This usually happens when the unit has a restricted view of the sky such as out the side window of an airplane.
You will likely need an autolocate if you have let the almanac data get out of date by not using the unit for 3 months or more. You may need an autolocate if the internal clock is totally wrong although usually a EZinit will work in this case. Since the etrex, 76 family, GPSV, and emap do not have an internal battery backup this can occur on those units if the main batteries are left out for several weeks. Finally you may need an autolocate if you are somewhere in or over the ocean without a clue as to where you are. Under some conditions where the unit just refuses to lock you might want to use the undocumented clear unit command (See the chapter on Undocumented commands) to completely clear the unit of all information and do an autolocate to get it running again.
